Layout problem Inside responsive Tab
satish
Inside responsive tab, I added layout widget with two columns and kept 10px spacing. I added panel in both columns. In composer preview, I can see spacing gap between tab boarder and layout columns boarder from all sides. However when I view mashup, then it shows spacing gap only between two layout columns. But it does not show spacing gap between tab borders and column borders.
I am using 6.0.2 TW version and Chrome 43.0 version.
I do not face this problem in previous version TW5.0. This seems to be bug TW 6.0.2.
Regards
Satish
2 REPLIES 2
satish
(To:satish)
Did anyone face this problem TW6.0.2? Can you please suggest how to fix this problem? Without spacing inside tab, UI does not look good.
satish
(To:satish)
This problem occurs only if tree widget is used inside tab. Solved this problem by adding extra layout widget in tab with left and side bars with 5px spacing.
