Inside responsive tab, I added layout widget with two columns and kept 10px spacing. I added panel in both columns. In composer preview, I can see spacing gap between tab boarder and layout columns boarder from all sides. However when I view mashup, then it shows spacing gap only between two layout columns. But it does not show spacing gap between tab borders and column borders.
I am using 6.0.2 TW version and Chrome 43.0 version.
I do not face this problem in previous version TW5.0. This seems to be bug TW 6.0.2.
Satish
Did anyone face this problem TW6.0.2? Can you please suggest how to fix this problem? Without spacing inside tab, UI does not look good.
This problem occurs only if tree widget is used inside tab. Solved this problem by adding extra layout widget in tab with left and side bars with 5px spacing.
