The message you are trying to access is permanently deleted.
Hi Folks,
Is there any limit of Properties per Thing?
I have a MQTT Thing with more than 1,00,000 Properties(Topics) in it. Is it going to impact my application in any negative way?
Thanks.
There is no predefined limit on the property of a thing .For more information you can check this article :
https://www.ptc.com/en/support/article?n=CS203736&source=snippet
Mukul Narang
Hi Mukul,
Thanks for the reply.
I saw that article and yes there is no limit but whenever I try to open that THING in composer,it almost kill the system.
Also, wanted to confirm if this approach won't impact the response of the Devices onto Mashups?
Thanks.
Frankly ,I never had any experience having 100K properties on a single thing .But as it will be difficult to manage and as you said it is almost killing the system .You should segregate these in multiple things .
Thanks ,
Mukul Narang
