Limit of properties per Thing
TanmeyTWX
Hi Folks,
Is there any limit of Properties per Thing?
I have a MQTT Thing with more than 1,00,000 Properties(Topics) in it. Is it going to impact my application in any negative way?
Thanks.
3 REPLIES 3
mnarang
(To:TanmeyTWX)
There is no predefined limit on the property of a thing .For more information you can check this article :
https://www.ptc.com/en/support/article?n=CS203736&source=snippet
Mukul Narang
TanmeyTWX
(To:mnarang)
Hi Mukul,
Thanks for the reply.
I saw that article and yes there is no limit but whenever I try to open that THING in composer,it almost kill the system.
Also, wanted to confirm if this approach won't impact the response of the Devices onto Mashups?
Thanks.
mnarang
(To:TanmeyTWX)
Frankly ,I never had any experience having 100K properties on a single thing .But as it will be difficult to manage and as you said it is almost killing the system .You should segregate these in multiple things .
Thanks ,
Mukul Narang
