Linking Toggle Button With Thing Property in Thingworx
Telles
Hi, Team!
I looking for a way to send a boolean variable to my microcontroller.
I try to linked the Property Thing LED1 to Toogle Button, but isn´t work.
How I can link the Toogle Button with Toogle Button?
Telles.
PaiChung
22-Sapphire I
(To:Telles)
Values that come in from GetPropertyValues (getter) are the values that are read from the Property.
To have two way interaction, you will need a 'setter' service to take the value back and apply it back to the Property.
I think ... if you want to accomplish this with a toggle, you'll want to
getter -> mashup parameter -> toggle
mashup parameter toggle value on change event to do the setter
Be sure to account for the fact that the getter may change the value as well and cause a trigger - I would validate that setter value != property value before applying value.
Telles
(To:PaiChung)
Hi, @PaiChung !
Thanks for aswer me!
Trying to do yours steps but isn´t work, like printscreens.
The refresh updating, I just doing in Gauges, it´s easy and I believe doint it as same way.
The first step is just implement the Bollean Variable to Toogle Button.
Telles.
PaiChung
22-Sapphire I
(To:Telles)
I do not see the use of a Mashup Parameter in your wiring. Currently I'm just seeing you bind your getpropertyvalues to the toggle and then to the label. With this approach you won't be able to do a getter/setter functionality the way I described it.
Telles
(To:PaiChung)
Hi, @PaiChung .
I try to attach the STATE OF TOGGLE BUTTON in my LED1 PROPERTY by Bollean Variable, from my Thing named Box.
 I wanna do the arrow flux
Telles.
