Out of List/Dropdown/ComboBox - which one will work efficiently?? Iam facing slowness in combobox
There was a bug in list widget of 8.4. Now in 9.2 version all problems related to list solved.
Can you check with the Dev tools open so it can show you what exactly takes how much time?
i tried using chrome's F12 developer option. Am not able to see execution time of code. Can you guide me where exactly we can see the execution time??
It would be on the Network tab
Hi @AP_9587236.
Have you found a solution to your problem? If so, please post it here and mark it as the Accepted Solution for the benefit of others with the same issue.
--Sharon
