List select everything by default
fgrondin
Hey guys,
How can I select all item in the list by default? Now this is what I have so far, but as you see, the selected rows in the list doesn't show anything. But then, if I change the selection, the grid is populated with the new selected item. So basically, I can select every rows by default, but the it appears like the selected rows is null. And I would need the selected rows to be All instead at default.
posipova
20-Turquoise
(To:fgrondin)
I created a Jira on this, /PSPT-3737.
I can select all items of the list at default (upon mashup loading) but they do not reflect in the grid immediately:
3 REPLIES 3
posipova
20-Turquoise
(To:fgrondin)
Let me run this on my instance, and I will get back to you soon.
fgrondin
(To:posipova)
Just for more information about this,
I've tried adding a property like the autoselectfirstrow.
I've got this part of code which doesn't work.
//else if ( this.getProperty( 'SelectAllDefault' ) === true )
                    //    TW.log.error( "1b" );
                    //    // do this with delay ... if you have a lot of grids accessing the same data, they may not have populated and we're already telling them the row to select
                    //    setTimeout( function ()
                    //        // make sure we haven't been destroyed
                    //        if ( mygrid !== null )
                    //            TW.log.error( "2b" );
                    //            // select the first row
                    //            var numRows = mygrid.getRowsNum();
                    //            TW.log.error( numRows );
                    //            var selected = [];
                    //            for ( var i = 0; i < numRows; i++ )
                    //                selected.push( i );
                    //                TW.log.error( "numb : "  +numRows );
                    //            thisWidget.ignoreSelectionChanges = true;
                    //            for ( var i = 0; i < selected.length; i++ )
                    //                mygrid.selectRow( selected, false, false, true );
                    //                TW.log.error( "selected : " + selected );
                    //            thisWidget.ignoreSelectionChanges = false;
                    //            thisWidget.updateSelection( 'Data', selected );
                    //    }, 100 );
posipova
20-Turquoise
(To:fgrondin)
