Lit Library issue in Thingworx
pshashipreetham
Trying to develop an Google Chart widget extension, when imported the Extension in to the TWX shows following error:
Attached the Extension Zip File for reference
@slangley  @c_lowy @PaiChung @CarlesColl  @VladimirRosu @VladimirN @Rajkumar_20673
Shashi.
Shashi Preetham
Found the solution,
Got this issue when we were using npm libraries in polymer.js. Instead of using npm libraries, we used the file.js file format
Shashi.
Shashi Preetham
Hi @psp316r
Can you confirm you're getting the 404 error on import?  Is the same issue you reported under this post?
--Sharon
Yes @slangley, i'm getting an error after importing
Hi @Rajkumar_20673
It's still not clear at what point you're receiving the error--during the import process, or after the import when you're attempting to use the extension.
--Sharon
@slangley ,
I replicated this issue with the attached widget and I'm getting the same errors.  The widget imports into ThingWorx just fine.  However, when you try and render the widget on a mashup, it gives those 404 errors.  After looking through the /extensions folder on the server, those libraries are indeed present but for some reason ThingWorx still returns a 404.
-Nick
Found the solution,
Shashi.
Shashi Preetham
