Hello All,
I don't remember -- was there a way to load some custom entities and/or install extensions as part of ThingWorx initialization? Similar to how it fills the database with things like SystemRepository the first time it starts.
Constantine
Hi Constantine,
I do not know any OOTB method to do that, you could use REST API in a post-installation script immediately after installing Thingworx, but don't know if this is what you really need.
Best regards,
Raluca Edu
Hi Constantine,
Best regards,
Raluca Edu
