Loaded 'validation.properties' properties file *** CRITICAL ERROR ON STARTUP: Unable to initialize and start system: Connections could not be acquired from the underlying database!
yingziDing
     The Thingworx platform I deployed doesn't work today.
     The version I installed is Thingworx 7.3 . And Used the postgresql 9.4 as database.
      When I used the url "localhost/Thingworx"  to visit the platform, it displays like the picture below.
And this is log file in Tomcat
2017-09-26 14:40:46 Commons Daemon procrun stdout initialized
Attempting to load ESAPI.properties via file I/O.
Attempting to load ESAPI.properties as resource file via file I/O.
Found in 'org.owasp.esapi.resources' directory: C:\ThingworxStorage\esapi\ESAPI.properties
Loaded 'ESAPI.properties' properties file
Attempting to load validation.properties via file I/O.
Attempting to load validation.properties as resource file via file I/O.
Found in 'org.owasp.esapi.resources' directory: C:\ThingworxStorage\esapi\validation.properties
*** Web Application STATE is being set to ERROR! ***
org.tuckey.web.filters.urlrewrite.UrlRewriteFilter INFO: destroy called
2017-09-26 15:00:30 Commons Daemon procrun stdout initialized
2017-09-26 15:07:51 Commons Daemon procrun stdout initialized
wish your help!
yingziDing
(To:jdass)
Thanks Janet Joseph Antony Dass
I followed the article. When I checked the PostgreSQL logs, there was an error about pg_hda.conf.
The platform works again.
3 REPLIES 3
jdass
(To:yingziDing)
Hi yz ding,
Please try the resolutions given in this Article. And let us know if you still face any issues.
Article Viewer | PTC
yingziDing
(To:jdass)
posipova
20-Turquoise
(To:yingziDing)
Ensure your postgresql db is running (in pg admin III, you may right click on the database to establish connection as an option from the selection).
