Local Binding Limits in Thingworx
Yedukrishnan
I need to bind one property of a thing to another property in 200 or more things. Is it recommended? If not, please suggest a better alternative.
I have shared the requirement in the diagram given below.
With regards
Yedukrishnan
1 ACCEPTED SOLUTION
Yedukrishnan
(To:slangley)
Hi @slangley,
We put local binding to matching properties of 150 things and are working fine in runtime. I needed to understand the impact it could cause in runtime.
With regards
Yedukrishnan U
7 REPLIES 7
Hello @Yedukrishnan
your image did not attach successfully.
Yedukrishnan
(To:PEHOWE)
Hi @PEHOWE ,
I have attached the image in previous comment.
With regards
Yedukrishnan
@Yedukrishnan
Can you provide more information on the nature of the information you are trying to bind.
  • How often is the value updated?
  • Is there a requirement for update speed?
  • Do you know how you are going to maintain that number of bindings?
  • Is this a relationship which will need to be recreated for new Things?
slangley
23-Emerald II
(To:Yedukrishnan)
Hi @Yedukrishnan.
If I'm understanding your requirements, you simply need to create a thing shape to extend the properties.  If this is not correct, please provide more details around your use case so we can respond accordingly.
--Sharon
slangley
23-Emerald II
(To:slangley)
Hi @Yedukrishnan.
If you have found a solution to your problem, please mark one of the previous posts, if appropriate, or post your own solution here for the benefit of others on the community.
--Sharon
Yedukrishnan
(To:slangley)
Hi @slangley,
With regards
Yedukrishnan U
