Local bindings on properties
vijay5
Hello Team,
Can you please brief on the purpose and and working of local bindings on properties
The properties are kept in separate Thing Entities, but certain properties are meaningful for other entities as well.
So to keep a record of the properties I need, I would create several properties in my Thing, and local-binding them to the properties I need from other Things, or else I need to write services to extract value from elsewhere with code { my.value = Thing["Other_Entity"].value ; } and keep them triggered on every valuechange events.
Creating a local variable and bind it to a global variable is very common in coding, and in TWX syntax, I have a remote Thing receiving data from some end devices, and I created a separate Thing, inheriting the properties from this remote Thing, and write some extra functions on it could also be very common.  The Local-binding is just a value reference, it's not a big deal.
vijay5
(To:zyuan1)
Thanks, Got it
Ok, and you can mark the previous answer as correct and close this thread
