Location values are rounded up after 4th place after decimal
sostwal
I am using the same code to incorporate data in property, but when i check my location is getting only 4 digits after decimal point, for example - 10.11012734  is sent to property as 10.1101 can you please tell why is it happening?
Message was edited by: Sushant Pandey : branched from https://community.thingworx.com/thread/39200?sr=inbox&ru=13756
supandey
(To:sostwal)
Swaraj, where do you see this effect? Are you observing this in a Data Grid widget on a Mashup?
We are facing this issue while inserting the data from property to datatable.
Swaraj
supandey
(To:sostwal)
Do you see this effect prior to insertion or after? How are you viewing the values? Did you create mashup with a Grid to display the values?
Issue was found after insertion, we are viewing the values in data table using getdatatableentrieswithdata. We are also showing this data on google map in a mashup.
