I am using the same code to incorporate data in property, but when i check my location is getting only 4 digits after decimal point, for example - 10.11012734 is sent to property as 10.1101 can you please tell why is it happening?
Message was edited by: Sushant Pandey : branched from https://community.thingworx.com/thread/39200?sr=inbox&ru=13756
Swaraj, where do you see this effect? Are you observing this in a Data Grid widget on a Mashup?
We are facing this issue while inserting the data from property to datatable.
Swaraj
Do you see this effect prior to insertion or after? How are you viewing the values? Did you create mashup with a Grid to display the values?
Issue was found after insertion, we are viewing the values in data table using getdatatableentrieswithdata. We are also showing this data on google map in a mashup.
