The Logout button is used to end the current User session, you need to re-sign in;
If you just need a button that helps you go to another mashup page, you should use Navigation widget with - Replace selection in TargetWindow field
That one means after you re-signin, the mashup you opened will be the redirected to the one you configured.
Is there any way we can redirect the user to a logout page after he clicks on Logout! I tried doing that with a navigate button which redirects to a log out mashup and then invokes the teminateSession service on mashup load up but its not working for normal users except for the admins!
Hi @biswa.
If one of the previous responses helped to resolve your issue, please mark the appropriate one as the Accepted Solution for the benefit of others with the same issue.
--Sharon
