Hello All,
I am having a hard time to get this use case to work: I need to iterate through a JSON nested structrure and check some fields to populate an infotable. I tried many approach but did not get it working. Here is the structure:
I need to get the value of the field "fields" and check its value, and iterate it trough all the entries inside the "histories" structure. BTW, there is only one instance of Histories inside changelog.
I tried to create an object only for the Histories doing:
var jsonHistories=jsonJira.changelog.histories;
but still cannot get it to work.
Any help is appreciated.
Cheers
Ewerton
Should be easy
// -- You need to create a DataShape with the structure you want the infotable, let's say it "MyDataShape"
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({
infoTableName : "InfoTable",
dataShapeName : "MyDataShpe"
var histories = jsonJira.changelog.histories;
var history,item;
for (var i=0;i<histories.length;i++) {
history = histories;
for (var j=0;j<history.items.length;j++) {
item = history.items
if (item.field==="whateverYouWantToCheck") {
// -- Let's add the data to the infotable
result.AddRow({ field: item.field, toString: item.toString, historyId: history.id });
Thanks Carles, I will try this approach to see if it is cleaner. For now, I seem to have achieved it by doing:
for(var i=0; i<jsonHistories.length; i++) {
var items=jsonHistories.items;
for(var j=0; j<items.length;j++){
itemField=items
if (itemField.field=="status"){
// jiraStates entry object
var newEntry = new Object();
newEntry.date = jsonHistories.created; // STRING - isPrimaryKey = true
newEntry.from = itemField.fromString; // STRING
newEntry.to = itemField.toString; // STRING
result.AddRow(newEntry);
Which is quite similar to what you are proposing
