MQTT to ActiveMQ
Saranya_S
MQTT to ActiveMQ
    I would like to achieve the following,
1. To send the remote thing values from ThingWorx to ActiveMQ using MQTT thing.Is it possible ? If its possible means how to publish the values to ActiveMQ.
Saranya
ActiveMQ supports MQTT and it could be treated like any other MQTT broker. For a basic test you could do this.
After downloading ActiveMQ binary, start it(navigate to bin folder and run activemq start). MQTT is enabled by default & it will be running on localhost at port 1883(default configuration). You will find the configuration in conf/activemq.xml file.
You could then follow this quick start guide to use MQTT extension to interact with it. In the guide Mosquitto is used as the broker.
2 REPLIES 2
slangley
(To:Saranya_S)
Hi @Saranya_S.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Thank you for your participation in our community!
--Sharon
