Hi guys,
What is the best way to connect two differents mashup. I want to do navigation mashup to mashup and I don't know if I have to use link, create service or use widgets ?
Guillaume
I'd check out the navigation widget. You should just have to specify the name of the other mashup and any values for mashup parameters if applicable. It is fairly simple to use. Hope this helps!
Yes, agree with Tori “Navigation Widget” should solve your purpose which allows you to link to other Mashups from within a current Mashup.You can open linked mashup in the current window (replace) or open a new window.
There are other ways of Navigation in Thingworx and recommend you to view the following video tutorial for more information:
Navigation in ThingWorx: Using Menus, the Navigation Widget, Link Widget, and Contained Mashups
https://www.youtube.com/watch?v=2wRiNBqDUUs&feature=youtu.be
Work perfectly, thanks !
