Mashup conversion from static to responsive
Willie
Is there a way to convert a static mashup to a responsive mashup (advanced)?
It would be nice if this is possible since I don't want to start all over and bind the services to the widgets and also set up all the validators.
Hi @slangley ,
It seems that I had mashups (static/responsive) mixed up with layouts and panels.
I didn't know I was using a responsive mashup.  In this responsive mashup, I had a panel in panel to create static dimensions.  I removed the panels and replaced them with layouts so that the widgets would work with any screen resolution.
Now I understand that a static mashup requires height and width dimensions and a responsive mashup does not since it is dynamic.
6 REPLIES 6
Willie
(To:Willie)
Answer: Not possible as of 5/2018
https://www.ptc.com/en/support/article?n=CS286115
slangley
(To:Willie)
Hi @Willie.
You can copy/paste between mashups but of course, this will not carry over the bindings.  Which version of ThingWorx are you running?
--Sharon
Hi @slangley,
I was able to work around it by using layouts.  I was only using panels initially.  I am on 8.4.5.
slangley
(To:slangley)
Hi @Willie.
Did we not understand your question initially?  We thought you were asking how to convert a static layout to a responsive one.  How does using layouts help with the conversion?
--Sharon
Hi @slangley ,
slangley
(To:slangley)
Hi @Willie.
If you have no remaining questions, it would be appreciated if you marked your last post as the Accepted Solution for the benefit of others with the same question.
--Sharon
