Mashup resolution
kbadr
2-Explorer
Mashup resolution
I would like to ask about if i chose the dynamic Mashup, so the visualization will be adapted automatically to the screen resolution?
As this is my working arera but when i make view mashup its not covered all the screen
3 REPLIES 3
ptc-6292103
(To:kbadr)
That looks like you have a fixed-size Shape on a dynamic-sized Panel in a responsive mashup.
Widgets will only be responsive when they are dropped into a dynamic region.
ankigupta
(To:kbadr)
Hi Karim BADR​, Try using layout widget to create various columns and rows. Then place your responsive widgets in the cells and it will cover the complete cell.
If you use a Panel widget anywhere in the Responsive Mashup; that part will be Static.
kbadr
2-Explorer
(To:ankigupta)
OK Thanks alot
Otherwise I define the resolution of the screen where I work (eg 1920*1080)
