Missing installation and troubleshooting guides
Alessio
Hi
It seems that under https://developer.thingworx.com/resources the above guides are missing.
How can we obtain them?
serler
7-Bedrock
(To:Alessio)
Alessio
(To:serler)
So there is no specific guide for the trial installer? Does JAVA_HOME need to be defined? Should the JDK bin be in the PATH?
Anyway, the two links I pointed out before are broken and must be fixed, or removed.
serler
7-Bedrock
(To:Alessio)
Hello Alessio,
Yes, as it seems unfortunately the two links are broken at the moment. I just tried the installation of the trial and for me setting JAVA_HOME and JDK in PATH was not necessary.
slangley
(To:Alessio)
Hi @Alessio.
The installation documentation for the trial versions can be found here.
The foundation installers available in the Help Center are for licensed versions of the products--not trials.
--Sharon
