Mobile mashups in ThingWorx
SOLVED
Level 7
We have created a ThingWorx application as per customer requirement. Now they wanted to see the mashup on mobile browser as well. Any one please help me, how to create mashup with the similar functionality which going to access via mobile.
Re: Mobile mashups in ThingWorx
The mashups can be accessed by a mobile device and you can interact with them. Once said this, of course if it aren't designed for a mobile screen it won't work well for user experience.
Having a real good UI experience it will be hard to reach with standard TW Mashups, better you go with a native mobile App or a Progressive/Web App using TW API to interact with TW Backend. If it's really a simple interface TW Mashups may do the trick, but you will need to add some custom headers on the Mashup in order to make it work properly as a "web app", TW support team has an extension to set that simple headers ask them.
Best Regards,
Carles.
Hi @Prem-IKEA.
You may want to start by checking out the various tutorials available on our Developer Portal.
--Sharon
Best Regards,
Carles.
Thanks Carlos!
Hi @Prem-IKEA.
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
--Sharon
