Modbus TCP/IP Ethernet feature in Thingworx Industrial Connectivity
SaranKarthick
Hi Developers,
I'm using ThingWorx-Industrial-Connectivity-8-3.
I had crested a new channel with Driver as Modbus TCP/IP Ethernet and with below properties. Property groups were set to default values. Then i added a device. I'm getting the following Licensing warning.
Time limited usage period on feature Modbus TCP/IP Ethernet has expired.
How do i validate if i have proper licenses?
Please provide help on this.
Thanks and Regards,
Saran
1 ACCEPTED SOLUTION
Hello @SaranKarthick,
You can use "LicenseUtility" application to validate your license.
VR
8 REPLIES 8
VR
Hi @Velkumar,
Based on your suggestion i looked into license utility and found my license page in the below state.
I'm following a guide ("https://www.kepware.com/getattachment/72292526-7770-4dfb-af73-2e0ab779cd57/license-utility-manual.pdf " ) to activate my licenses. But I'm not able to find the activation id. Is it auto generated or will be given in some shipment documents.
Saran
Hi @SaranKarthick
You will get activation ID when you purchase kepServerEx license.
VR
Hi @Velkumar,
I have downloaded "Thingworx Industrial Connectivity 8.3" from the PTC software downloads. I didn't receive any Activations IDs.
Saran
You can contact your PTC representative for license related queries.
VR
Hi @Velkumar,
To be clear without Activation ID we can't do any kind of activation (Online and Offline). Is there any other way to get this activation Id from the installed machine?
Reagrds,
Saran
No, We cannot do anything without activation ID.
VR
Thanks @Velkumar. I'm got the necessary informations regarding this issue
