Multiple Inputs to Expression
pshashipreetham
I had a situation where the same expression Function to be used in three different labels.
  • Input to Expression is Different Services Output
  • The output of Expression is a String that should be given to different Labels
I have three Labels, and three different services as an input to the expression.
Shashi Preetham
1 ACCEPTED SOLUTION
@pshashipreetham : You can add multiple parameters in expression functions and the values for these parameters can be from you three services.
abjain
(To:abjain)
Hi @pshashipreetham
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Abhinav
