My google map widget disable on page refresh of mashups
bgupta-2
9-Granite
Dear Team,
My google map widget disable on page refresh mashups. It is showing properly on first time of page load.But once I am reloading on same window it showing blank.
I am sharing screen
This is first time page load showing google map.
once I am reloading page on same window, google map is not showing on page.
ytella
(To:bgupta-2)
Hi Bhuwaneshwar Gupta,
Do you see this issue when you try it on different browsers? Also, please share the mashup log after reloading the window. { After reloading the window, click on show/Hide Log and share the screenshot of the log information}
Thanks Yamini,
Sharing screen of show.hide log
I am unable to attach log file. So, I am sending log file to your mail id.
ytella
(To:bgupta-2)
Thanks for providing the logs. I have observed the following error in the application log:
Unable to dispatch [ uri = /Things/*TL00021/Services/UpdateSubscribedPropertyValues/]: Entity *TL00021 does not exist or is not yet associated with a Thing
error executing APIRequest Message: Entity *TL00021 does not exist or is not yet associated with a Thing, sending ERROR ResponseMessage to caller!
If you are using the things on Edge device then, could you please review the below information and make the changes if necessary?
  • Make sure that there are no spaces in the identifier on the Edge device.
  • Also, make sure that the edge device is configured with the proper AppKey and IP Address so that it is making a connection to the Remote Thing in Composer.
HI Yamini,
Thanks for reply.
That is edge side error. But why google map is not loading when I am reloading page.
