.NET SDK examples-File watcher
byutz
Hello Everyone!
I have been working with the .NET SDK and can't seem to find any examples of File Watching and was curious if anyone knew if this is built into this SDK?  I have combed through the c sdk and it has several more examples, one where they call a method twFileManager_ListEntities(thingName, WATCHED_DIR, NULL, LIST_FILES).  The example then compares file listings of a folder and uploads any new files to thingworx.  I have tried to look for something similar with the .NET SDK and can't find it anywhere.  Can anyone shed some light on this? Thanks for your time!
Brian
byutz
(To:byutz)
Here is an example of how to use the file watcher class with .net sdk.  It apparently isn't built in to the sdk because the microsoft class available does such a good job.
FileSystemWatcher Class (System.IO)
byutz
(To:byutz)
