Network error with Thingworx Analytics server URL
Highlighted
Newbie
Hello everyone,
I have installed Docker community edition with version 17.06.2-ce-win27  on windows 10 desktop grade machine.
Then docker based analytics server with version 8.0   is installed on that.
after installing docker analytics server URL also generated.
http://10.0.75.1:8080/analytics/1.0.
after running URL,getting below error.
can any one help on that.
Raji
22 REPLIES 22
Highlighted
Re: Network error with Thingworx Analytics server URL
Hi Raji Vuta
Could you please check in docker settings that your all the drives are shared or not. For windows 10 we use the native docker make sure you are using the same not docker toolbox. Please see the below screenshot for the same.
Please send me the result of these commands in docker terminal: 1) docker ps -a  2) docker logs analytics
Mohit Goel
Highlighted
Hi Mohit,
Thanks for your response.
Please check below screenshots of commands.
docker ps -a
Highlighted
Hi Raji Vuta
Please check both c and d drive in the settings share drive option and follow the below article, hopefully it will help.
https://www.ptc.com/en/support/article?n=CS265097&posno=1&q=Error%20%22This%20page%20cannot%20be%20d...
Do let me knoe in case of any question.
Mohit Goel
Highlighted
Hi Mohit Goel,
As per suggested blog, I changed the install file,
but still issue not resolved.
Highlighted
Raji
The analytics log shows that it is trying to connect to a postgres instance on 10.0.75.1 on port 9000.
Do you have a PostgreSQL instance on this machine and on this port ?
Kind regards
Christophe
Highlighted
Hi Christophe Morfin,
Yes ,postgreSQL instance is there on this machine.
I did reinstallation,with new port.
Docker analytics log is as below.
Please help.
Hi Raji
If Postgres is running on the host machine, as it seems to be the case, use the external ip address of that machine, not localhost or 127.0.0.1.
Indeed using localhost (or 127.0.0.1) will be interpreted by the docker container as itself and it is looking for a postgres instance inside the container, which it cannot found.
Kind regards
Christophe
Highlighted
Dear Christophe Morfin,
If Iam trying to give IP  address ,then below error is coming.
With localhost validation is getting successful
Highlighted
Hi Raji
Could you please post the net.txt and ipconf.txt files created with the commands below when executed on the host machine on which you are installing ThingWorx Analytics Server
netstat -abo > net.txt
ipconfig /all > ipconf.txt
Kind regards
Christophe
Highlighted
Thank you so much for your response.
Please check attached file.
Highlighted
Hi Raji
Thank you.
The connection details seems ok.
So if postgres is accepting connection on localhost but not on your ip, it is very likely because Postgres is not configured to accept such connection.
You could check the postgres log file, I would think you should see error like:
FATAL: no pg_hba.conf entry for host "172.29.50.129", user "postgres", database "postgres", SSL off
By default Postgres is configure to accept only connection from localhost.
You would need to update postgres pg_hba.conf file to allow connection from your ip.
See http://support.ptc.com/WCMS/files/173600/en/Installing_ThingWorx_8.1_1.3.pdf page 10 for some examples.
Then restart Postgres and try again .
You should also confirm that you are able to connect using pgadmin to Postgres using the exact same details as in the Installer (that i using the ip and not localhost)
Kind regards
Christophe
Highlighted
As you suggested updated pg_hba.conf file and cross checked connectivity with IP using PgAdmin.
Its working fine.Also IP address accepted for postgreSQL while installing Thingworx server.
But getting  below error.
Highlighted
Hi Raji
You are getting a Permission denied error.
Could you make sure that when we start the installer you don't just double click on it but instead right mouse button and select Run As Administrator ?
Chrisotphe
Highlighted
I tried as "Run as Administrator" only..But same error is coming.
Raji
Highlighted
Hi Raji
Do you have something running on port 8080 on the host machine ?
For example do you have ThingWorx Platform running on the host machine ?
The output of netstat -abo can be useful for that.
Kind rgeards
Christophe
Highlighted
HI,
Please check below response
Highlighted
Hi Raji
So you do have something running on port 8080 on the host machine, so the Analytics Server cannot run also on port 8080.
From the log files the container is being created on port 8080, which is already in used, so that is probably what is leading to the Permission Denied.
During the installation, in the page ThingWorx Analytics Server Configuration, could you try entering a free port on the host machine for the field Tomcat External Port ?
Thank you
Kind rgeards
Christophe
Highlighted
After changing the port, installation was successful.
but again network error is coming.
Raji
Highlighted
Hi Raji
Could you post the analytics.log file created with command  docker logs analytics > analytics.log
Kind regards
Christophe
Highlighted
Please check log file.
Raji
Highlighted
Hi Raji
From this the Analytics container appear ok.
Could you send:
- the output of docker ps -a
- a screenshot of the error form the browser (as you posted earlier) BUT showing the url accessed
Thank you
Kind regards
Christophe
Highlighted
Hi Christophe
Raji
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum!
