I have been trying to connect the Azure IoT hub to my Thingworx platform. I have followed every steps in documentation and ab able to get cx-server in platforms monitoring>connection server. But the thing which I have created is not able to connect to the Iot hub connector.
ThingWorx platform: 9
Thingworx-Azure-IoT-Hub-Connector-4.2.0.4
Hii PaiChung,
Thanks for the reply after resetting the AzureIoTHubThing it connected.
What sort of output are you getting in the different logs? Both on the connector side and within ThingWorx?
Hello PaiChung,
Attaching cxserver and thingworx log files and am connecting to platform without ssl.
kindly help on this.
I can't say for sure what your issue is.
on the one side it seems to run out of 'buffer space' and you are losing updates.
In the other log it is talking about some permissions issue limiting what can be done.
I'd try to tackle the permissions issue first.
You then may have to do some 'reset' to potentially clear out the buffer build up.
Hii PaiChung,
