We are working to address an issue with subscription email notifications. In the meantime, be sure to check your favorite boards for new topics.
Not able to get correct language in widgets
KV_10974131
6-Contributor
Hello
I am using some customized fonts in our thingworx on premise instance and facing the language issues now after importing it .
The issue is abrupt with some of the widgets where its mix of both the languages.
1 ACCEPTED SOLUTION
Hello @KV_10974131 ,
The similar query has been answered previously. You can go through the following community post linked below:
https://community.ptc.com/t5/ThingWorx-Developers/DatePicker-widget-language-error/m-p/942271#M66310%3Fsource=search
Pls let me know if you have any further questions.
Bhawna
1 REPLY 1
Bhawna
