Not authorized for PropertyWrite
振霍
I used kafka, but when I assign a value to a property, there's an error:com.thingworx.common.exceptions.InvalidRequestException: Not authorized for PropertyWrite on strvalue in TestReceiver
@ThingworxPropertyDefinitions(properties = {
@ThingworxPropertyDefinition(name = "strvalue", description = "", category = "", baseType = "STRING", aspects = {"isReadOnly:false","isPersistent:true"}) })
setPropertyValue("strvalue", new StringPrimitive(results));
Please help me solve this problem.
7 REPLIES 7
PaiChung
22-Sapphire I
(To:振霍)
For the User that is doing the Write, did you verify permissions for Runtime Property Write in the platform?
振霍
(To:PaiChung)
My user is Administrator
PaiChung
22-Sapphire I
(To:振霍)
When you look in the Application Log in Thingworx, does it show that same error and Administrator as the user?
振霍
(To:PaiChung)
The user of the log is Administrator.
The exception was thrown to Tomcat.
PaiChung
22-Sapphire I
(To:振霍)
That doesn't make sense that you don't see that in the application log.
How are you doing the auth definition in your kafka code?
振霍
(To:PaiChung)
I wrote a timer in kafka's code to send a heartbeat to the producer.
@ThingworxServiceDefinition(name = "ReceiverStringMessage", description = "Receiver a string message to the specified Kafka")
@ThingworxServiceResult(name = "result", description = "", baseType = "STRING")
public String ReceiverStringMessage() throws Exception {
//String results = this.utils.ReceiverStringMessage(entity,strMap);
String msg = "";
//String state = "0";
    try {
    logger.info("开始接收数据:" + entity.getGetServerAddress() + "=====" + entity.getTopic() + "===" + entity.getZookeeperSyncTimeMs() + "===" + entity.getReceiveTimeout() + "===" + entity.getAutoCommitInterval()+"==="+entity.getFetch());
    consumer.subscribe(Collections.singletonList(entity.getTopic()));
    logger.info("consumer 订阅成功");
    //ConsumerRecords<String, String> records = consumer.poll(entity.getPollTimeout());
    logger.info("consumer 提取成功");
    //executor = new ScheduledThreadPoolExecutor(1);
    //Task5 task5 = new Task5();
    //mapMsg = new HashMap<String,String>();
    try{
    if(!atomic.get()){
    timer = new Timer();
    timer.scheduleAtFixedRate(new TimerTask() {
//KafkaReceiverThing kafkathing;
@Override
public void run() {
String message = "";
try{
     for (ConsumerRecord<String, String> record : records) {
     if(record.value() != null && record.value() != "" ){
     message += record.value() + ";";
     if(message != null && message != "" ){
     logger.info("数据获取成功111111:" + message);
     json = new JSONObject();
     json.put("state", state);
     json.put("msg", message);
     logger.info("收到的消息:"+json.toString());
     strMap.put("mapmsg2", json.toString());
     logger.info("map value:"+strMap.get("mapmsg2"));
     results = strMap.get("mapmsg2");
     logger.info("收到的数据有值:"+results);
     //logger.info("property value:"+GetPropertyDefinition("strvalue"));
     //logger.info("property value:"+GetPropertyDefinition("strvalue").getFirstRow().getStringValue("value"));
     //String msg = getPropertyValue("strvalue").toString();
     //logger.info("property value:"+msg);
     //logger.info("property length:"+GetPropertyDefinition("strvalue").getLength());
     }else{
     logger.info("收到的数据为空:"+results);
     } catch (JSONException e) {
     e.printStackTrace();
     } catch (Exception e) {
// 添加kafkathing.GetPropertyDefinition("strvalue").getReturnValue()方法后抛出的异常
}, 0, 10000);
    } catch (WakeupException e){
    if (!atomic.get()) throw e;
    state = "1";
    msg = "获取数据失败";
    logger.info("获取数据失败222222:" + e.getLocalizedMessage());
logger.info("接收到的数据为:"+strMap.get("mapmsg2"));
return results;
振霍
(To:PaiChung)
You can now display the same errors and administrators as the user.
