Not authorized for PropertyWrite
振霍
1-Newbie
I used kafka, but when I assign a value to a property, there's an error:com.thingworx.common.exceptions.InvalidRequestException: Not authorized for PropertyWrite on strvalue in TestReceiver
@ThingworxPropertyDefinitions(properties = {
@ThingworxPropertyDefinition(name = "strvalue", description = "", category = "", baseType = "STRING", aspects = {"isReadOnly:false","isPersistent:true"}) })
setPropertyValue("strvalue", new StringPrimitive(results));
Please help me solve this problem.
7 REPLIES 7
PaiChung
22-Sapphire I
(To:振霍)
For the User that is doing the Write, did you verify permissions for Runtime Property Write in the platform?
My user is Administrator
PaiChung
22-Sapphire I
(To:振霍)
When you look in the Application Log in Thingworx, does it show that same error and Administrator as the user?
The user of the log is Administrator.
The exception was thrown to Tomcat.
PaiChung
22-Sapphire I
(To:振霍)
That doesn't make sense that you don't see that in the application log.
How are you doing the auth definition in your kafka code?
I wrote a timer in kafka's code to send a heartbeat to the producer.
@ThingworxServiceDefinition(name = "ReceiverStringMessage", description = "Receiver a string message to the specified Kafka")
@ThingworxServiceResult(name = "result", description = "", baseType = "STRING")
public String ReceiverStringMessage() throws Exception {
//String results = this.utils.ReceiverStringMessage(entity,strMap);
String msg = "";
//String state = "0";
    try {
    logger.info("开始接收数据:" + entity.getGetServerAddress() + "=====" + entity.getTopic() + "===" + entity.getZookeeperSyncTimeMs() + "===" + entity.getReceiveTimeout() + "===" + entity.getAutoCommitInterval()+"==="+entity.getFetch());
    consumer.subscribe(Collections.singletonList(entity.getTopic()));
    logger.info("consumer 订阅成功");
    //ConsumerRecords<String, String> records = consumer.poll(entity.getPollTimeout());
    logger.info("consumer 提取成功");
    //executor = new ScheduledThreadPoolExecutor(1);
    //Task5 task5 = new Task5();
    //mapMsg = new HashMap<String,String>();
    try{
    if(!atomic.get()){
    timer = new Timer();
    timer.scheduleAtFixedRate(new TimerTask() {
//KafkaReceiverThing kafkathing;
@Override
public void run() {
String message = "";
try{
     for (ConsumerRecord<String, String> record : records) {
     if(record.value() != null && record.value() != "" ){
     message += record.value() + ";";
     if(message != null && message != "" ){
     logger.info("数据获取成功111111:" + message);
     json = new JSONObject();
     json.put("state", state);
     json.put("msg", message);
     logger.info("收到的消息:"+json.toString());
     strMap.put("mapmsg2", json.toString());
     logger.info("map value:"+strMap.get("mapmsg2"));
     results = strMap.get("mapmsg2");
     logger.info("收到的数据有值:"+results);
     //logger.info("property value:"+GetPropertyDefinition("strvalue"));
     //logger.info("property value:"+GetPropertyDefinition("strvalue").getFirstRow().getStringValue("value"));
     //String msg = getPropertyValue("strvalue").toString();
     //logger.info("property value:"+msg);
     //logger.info("property length:"+GetPropertyDefinition("strvalue").getLength());
     }else{
     logger.info("收到的数据为空:"+results);
     } catch (JSONException e) {
     e.printStackTrace();
     } catch (Exception e) {
// 添加kafkathing.GetPropertyDefinition("strvalue").getReturnValue()方法后抛出的异常
}, 0, 10000);
    } catch (WakeupException e){
    if (!atomic.get()) throw e;
    state = "1";
    msg = "获取数据失败";
    logger.info("获取数据失败222222:" + e.getLocalizedMessage());
logger.info("接收到的数据为:"+strMap.get("mapmsg2"));
return results;
You can now display the same errors and administrators as the user.
