Hello community,
I wanted to create a new mashup with a tab widget. I placed some widgets on the tabs and wanted to view the result in the browser. But if I open the mashup in the browser, I can see the default tab but can´t change to the other tabs.
Is there somewone who can help me with that problem?
franky_
Hi Vinícius,
thanks for answering.
Yes the tab buttons didn´t work. The only to solve that problem was to delete the complete tab widget and implement it new.
Franky
Hi Franky,
Can you post more information?
Console log in the browser or a print screen can be useful (both mashup builder or runtime).
How are you not able to change the tabs? Are the buttons not working? not changing? how many tabs do you put in the properties of the widget?
Vinícius.
Hi Vinícius,
Franky
