On project import the users passwords does not work
MA8731174
Hello community,
I have very strange issue when i import the project on for eg another server the users which are already there and get also imported on this project do not able to login with their passwords. Then i set the passwords again and everything works then for eg again after some time when i do import project with users the users passwords got disable and again i have to do this process.
I think i should not import users which are already present on the server..
14 REPLIES 14
Hi @MA8731174
Can you share the logs here, which type of error look at the logs, I want to know.
MA8731174
(To:Surya_Tiwari)
Hi @Surya_Tiwari  i could not see the logs at that time but when i update the password only then it starts working. I think the password get expired once you import the users. The users would be definitely there in platform but with expired password.
Hi @MA8731174  You have imported entity and data both or only entities?
MA8731174
(To:Surya_Tiwari)
I have imported the complete project but not data from datatables. It means all entities. source control entities.
Hi, @MA8731174  it means you have only imported entities,  this is the issue you need to import data, and then it will work.
MA8731174
(To:Surya_Tiwari)
which data i need to import? The data i can only import from Datatables but for user there is no data i can see. Would you please explain it more.
Hi @MA8731174  Yes you need to import data from the user table.
MA8731174
(To:Surya_Tiwari)
I could not understand you. When we do export we do fully project which also includes users. There are no user table for users i can see in export option. I have attached an image also. Would you please clarify it. Thank you
Hi @MA8731174  I have explained to you the DB label but at composer, look at the attached screenshot using the data collection, and let me know your feedback.
MA8731174
(To:Surya_Tiwari)
Thanks Surya but with this export , dont you think all the datatables with entries will be exported and i dont want that dataentries on the production server. What do you think about it?
I have done an export but with this all the datatables are coming in export and i dont want these entries to go on the production server. My issues with users come whenever i do export the project from dev to prod.
Hi, @MA8731174  There is no option for exporting data of particular entities in Thingworx, let me know if you have any other doubts.
MA8731174
(To:Surya_Tiwari)
thanks yeah i think next time i would just not import users if they are still present on the server where i will import..
do you have any idea about this below issue please ? it would be great! thanks
https://community.ptc.com/t5/ThingWorx-Developers/FileRepositry-Visibility-issue-fileuploader-widget/td-p/964418
Hi @MA8731174  sure, I will take a look and provide my findings in the same community post, kindly mark it as a solution.
Hi @MA8731174,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina
PTC Community Moderator
