PDF Extension 3.0 - CreatePDF - HTTPS Address
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Hello
Has anyone been successful with creating a PDF file using PDF Export service from the PDF extension 3.0, using an HTTPS address on ThingWorx 8.2.1.?
I have worked with this extension in the past with PDF extension 2.0 and this worked fine, however to note I was using a HTTP address.Also using ThingWorx 8.2.1.
Any support would be appreciated,
Sean
- Labels:
Extensions
Troubleshooting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
If you're using a PTC hosted instance, then you need to open a ticket to have some packages installed in that instance. Look at the latest post from https://community.ptc.com/t5/ThingWorx-Developers/PDFExport-not-working-on-Red-Hat-Linux/td-p/530697/page/4 . The background of this issue is that the third party component I'm using to render a page requires different packages for different OS versions, and those packages are not installed in the OS by default typically.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi Sean,
I did test it in 8.2.1 and it worked. Can you specify any additional details regarding your situation? Do you have an entry in the ApplicationLog? Does the service finishes running or is it forever running?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Thanks for the quick repsonse Vladimir.
I have attached the return I get after 5 mins, nothing seems to appear in the application logs.
Sean
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
If you delete the / from the file name does it work? So try with the filename as "Report.pdf".
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
@VladimirRosu Just tried that and it seems to be stuck on Executing. I am using an application key with Administrative powers too just for testing.
ServerAddress
https://localhost:443/Thingworx/Runtime/index.html#mashup=LogViewer
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
What operating system are you using? I mean the one where Tomcat is running.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I am unable to get the version of Tomcat as this is a PTC ThingWorx hosted solution. I would presume it to be same set up between other solutions.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Just a small ask, please let us know if this works after the modification has been done.
Thanks!
