Passing an Infotable into a Collection widget where the receiving widget in the child is a Chart.
AndyHilton
Thingworx 9.4.0.  I thought this would be straight-forward but it's been a nightmare.  As the subject states I'm trying to pass the data from an Infotable into a collection widget.
Setup:
Parent Mashup:
Collection widget:
Mashup -> set to Child mashup
MashupPropertyBinding:
"cva": "cva",
"cvu": "cvu",
"mva": "mva",
"mvu": "mvu",
"TagLabel": "TagLabel",
"TimeStamp": "TimeStamp"
Data Service: (Data Properties populated with values)
Child Mashup:
Mashup Parameter
LineTrendingVariables_DS:
Line Chart widget:  (Mashup Parameter data bound)
Result:
I was able to verify that the service is being processed and delivering data by placing a Grid widget in the Mashup to collect the data.  This was successful so I know there is data coming in:
Debug Info:
Here I can see that the system is showing DATA (The mashup parameter shown above in the Child mashup) as undefined.
NOTE:  I'm pretty sure the issue has to do with the MashupPropertyBinding formatting or content but I don't know what that issue might be.
Hi @AndyHilton ,
In collection MashupPropertyBinding  - JSON should be formed by {"DATASHAPE FIELD NAME" : "CHILD MASHUP PARAMETER NAME"}.
In your case have to create the cva, cvu, mva, mvu, TagLabel, TimeStamp each as mashup parameter(not as direct DATA Infotable) and then you can collect your data in child mashup but it will return the Data on child mashup based on the main service output of each row as in collection cells, not complete data in 1 collection cell.
Kindly refer these links -
 How to use the Collection Widget in ThingWorx
Infotable as parameter in collection widget
Please let me know if any other queries.
Thanks & Regards,
Arun C
11 REPLIES 11
Hi @AndyHilton ,
Thanks & Regards,
Arun C
Hi @AndyHilton
Adding to @Arun_C  point.
If you want to pass InfoTable value to the collection child mashup, your service should return the data as a Child InfoTable. Something like this
Collection MashupPropertyBinding should look like this
Output :
/VR
Hey @Velkumar,
What did you set the UIDField of the Collection widget to in your example?
Hi @AndyHilton
In my example, I have set rowNumber as UIDField which is unique for each row.
/VR
Hey @Velkumar,
Thank you.  Can you upload everything from your example?  I'm missing something simple but I just can't seem to figure out what it is.
Hi @AndyHilton
Please find attached example entities. Please do let me know if you need more details
/VR
Hey @Velkumar
Looks like I was unable to import due to the following.
Looks like there is a valueStream and DataShape connected that weren't included:
Hi @AndyHilton
My bad I included dependencies while exporting still some DS got missed. Please find updated entities
/VR
Hi @AndyHilton
Here I have posted step by step procedure for collection widget mapping.
How to add a progress bar in a grid column? - PTC Community
/VR
AndyHilton
(To:Arun_C)
Hey Arun,
If I create each of those as a mashup parameter I can't bind them to the Line Chart as you have to bind "Data" to Charts.  How would I then take all of the separate parameters and combine them as an All Data group?
If I create the parameters individually then the Data parameter of the Chart is not available to bind.
HI @AndyHilton ,
If you have to pass a infotable to collection means, Please find the below given process, It may helps you.
  • Create your main service with infotable field which contains the data for your collection's chart along with other required data fields for each row
  • Bind that service output to the collection's
  • In child mashup create infotable parameter (labelChartInfotable) and other required fields
  • In Collection - MashupPropertyBinding you need to form JSON
  • After that you can bind the mashup infotable parameter (labelChartInfotable) as input Data of your Chart in child mashup
Thanks & Regards,
Arun C
