Hello. Currently I have a Thing which create a Datatable from a service, I've assigned the permissions for a user group and it work perfectly fine (In a testing server).
I try to do the same in my production server but It doesn't work, it appears the next error.
Execution error in service script [IPE.Entity.Windchill.Miscelaneos CreateOfferDT] : Wrapped java.lang.Exception: Import Failed: Not authorized for Create Cause: Import Failed: Not authorized for Create
As I said, i already assigned all the permissions even in the EntityService Resource.
Thank You for your time.
What version of Thingworx?
Have you assigned Persistent Provider permissions? You may look into this for using SYstem user The use of System User
Hi, Polina. My Thingworx version is 7.3.3
I haven't assigned that permission, gonna try it and I tell you later if it works.
You would also need permission to Datatable and visibility to all data shapes/entity collections involved.
