Hi
I have Persistent infotable proeprty for my device.
I understood that persistent property is store data even if device goes to offline.
but I add some rows on my infortable and disconnect, reconnect device.
rows on infortable are disappeared.
Is is all right?
How can I maintain infortable's data?
You need to follow the approach from this article: https://www.ptc.com/en/support/article?n=CS227531
Recommendation is to clone infotable, perform the modification and after assign again the infotable to the original one.
Hope it helps,
Raluca Edu
Hope it helps,
Raluca Edu
Thank you!
It resolve my problem
