Planner Widget in Thingworx
SD_9183081
7-Bedrock
Is there any widget available in Thingworx like Planner? Following functionalities should be available :
1. It should look like a calendar.
2. On clicking the date Task add/delete, assign a task, etc. options should be there.
I am attaching a snapshot of the Microsoft planner as a reference.
slangley
(To:SD_9183081)
Hi @SD_9183081
I found your case and saw that the engineer did test the widget under ThingWorx 9.1 and found that it was not compatible with that version.  Since he has already verified that information, there is no need for a new case, as the results will be the same.
However, you may contact our Sales team for engaging with one of our consultants for either modifying the existing extension available on github or creating a new extension to better meet your needs.
--Sharon
8 REPLIES 8
slangley
(To:SD_9183081)
Hi @SD_9183081
There is a calendar extension available on github that might work for your purposes.  This is not maintained or supported by PTC, however.
You may also want to post your request on the ThingWorx Ideas forum.  This will allow others on the community to vote for it which will increase it's chances of being included in a future release.
--Sharon
I have tried to import it into my composer. It is showing imported successfully. But not showing in the list of the available widgets.
slangley
(To:SD_9183081)
Hi @SD_9183081
Do you see the extension when you navigate to Manage > Installed Extensions?
--Sharon
Yes. I can see the extension in the Installed Extension. But the 'Availability in Solution Central' is 'Not Connected'.
slangley
(To:SD_9183081)
Hi @SD_9183081
What version of ThingWorx are you running?  I think we probably need to open a case for this, and I will be happy to do so on your behalf, if you agree.
I am using Thingworx 9.1 and already opened a case for this. But PTC is saying that this widget is not supported by them.
You can open a case for this and please let me know if you get any solution.
slangley
(To:SD_9183081)
Hi @SD_9183081
--Sharon
slangley
(To:slangley)
Hi @SD_9183081
If you feel your question has been answered (even if it wasn't the answer you wanted), please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
