I put this here as I couldn't find the product ideas section for twx:
In 8.3 you decided to hide properties behind a chevron on right side, thereby adding a lot of clicks and mouse moving for the users. But no space is saved, as the line where the chevron is, is empty otherwise.
Please bring back the former UI where everything was visible in the first place.
Hi @Rocko this is not the right forum for entering product ideas. I would strongly recommend opening a support case.
FYI it's a problem of firefox and will be fixed in a later release. (TW-35192)
