Plot icons in a timeline
emoreira
Hello All,
I have a use case where I want to display different issues that happened in a machine throughout the day in a timeline to see concentrations of issues of the same type.
Does anyone have an idea of an approach to do it?
Cheers
Ewerton
emoreira
(To:emoreira)
Hello All,
I was able to get it working!
I only needed to use one data series, which I got from pulling the data from a Value Stream:
There is some configuration on the widget to be done but once I figure it would it was really easy:
Main trick was to change the marker size to control the Icon Size. Its default value is 3 so the icons are tiny.
Then I applied some State Based Formatting:
The result (not final) is something like this:
Every icon in the timeline is a different type of issue
Thanks Carles Coll​ and Bogdan Mihaiciuc​ for the tips.
Cheers
Ewerton
4 REPLIES 4
You can use a XY or a Label Chart, put on the X axis the hour of the day ( 0..24 ) and on the Y axis the repetition times number.
of course you will need multiple series in order to map different types of issues.
emoreira
(To:CarlesColl)
Thanks Carles,
Tried it but I don't seem to be able to make the Icons appear.Tried a state based formatting and the series formatting itself and did not succeed so far.
Also tried the event chart. Still struggling.
Cheers
Ewerton
emoreira
(To:emoreira)
Hello All,
Cheers
Ewerton
