Popup Mashup on Specific Data Series in Bar Chart
ST_14485832
3-Newcomer
I’m using the bar chart widget with 3 data series. Is it possible to configure a navigation mashup popup so that it appears only on one particular data series (instead of the whole chart)?
slangley
(To:ST_14485832)
Hi @ST_14485832.
I don't think it's possible to configure a navigation mashup popup to appear only on one particular data series within a bar chart widget in ThingWorx. The functionality typically applies to the entire chart rather than individual series.
You might want to check out the widgets available from IQNOX to see if they have an alternative solution.  I think they also do custom widget development if you are inclined to go that route.
--Sharon
