krishnakomal123
Popup
Is it possible to move popup screen with the help of cursor just like how popup windows(chrome window,settings window etc) we move?
Hi @krishnakomal123
No that is not possible.
You do need 8.5 to use the Navigation function.
Christophe
6 REPLIES 6
Hi @krishnakomal123
Using the Navigation function with popup or modal popup in ThingWorx 8.5 allows to move the popup inside the browser window.
The legacy Navigation widget does not allow this.
Christophe
krishnakomal123
(To:cmorfin)
We are using 8.3.3 version of thingworx now,Is it possible to the same in this version using css or any other method?If so,please let me know
Hi @krishnakomal123
I am not aware of a way around it in 8.3.3
Christophe
krishnakomal123
(To:cmorfin)
Can you send Navigation function widget as zip file so that I can import it into 8.3.3 as custom widget?
Hi @krishnakomal123
Christophe
Hi @krishnakomal123.
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
--Sharon
