I am trying to import PostgreSQL extension (http://marketplace.thingworx.com/Items/Relational-databases-connectors) to my freshly installed Thingworx 7.1 (Postgres version) and I am facing such problem:
In the logs I can see errors:
[message: Checking ThingWorx system JARS conflict(s) detected [package: PostgreSQL_ExtensionPackage]. Check application log for details!]
JAR conflict Checking ThingWorx system JARS [existing: postgresql-9.4-1201-jdbc4.jar, package: postgresql-9.4-1204-jdbc41.jar]
I believe that extension management tries to deploy jar with postgres connector classes, such jar already exists and that is causing the problem.
How to solve this properly?
Hi Jacek,
I faced the same problem and found a solution in PTC Support in this link. I hope it helps.
Also copied the solution below:
How to connect
Hi Jacek,
If you are familiar with the Extension development, you can get the extension and remove the included Postgresql jar file from the extesion.
Should be as easy as:
Carles.
Yeah Carlos, this is what I've done already.
However I am not sure whether this is correct approach (to modify existing extensions) - don't you think we should inform vendor of the extension (Thingworx in this case) that their extension is not working "as-is" with PostgreSQL version of Thingworx?
You can for sure, open a support case on the e-support portal.
Hi Jacek,
How to connect
It looks like that extension is meant for ThingWorx 7.2 PostgreSQL and later. If you look at the overview there is a bullet item stating this.
Regards
Meghan
Meghan sure? This 7.2 refers to PostgreSQL not to TW, TW 7.2 it's not yet released
I quickly googled supported jar versions, PostgreSQL JDBC Download, and 7.2 can use this jar version, so I'll make the Marketplace team aware of what's happening with this extension in PostgreSQL.
Thanks!
Meghan
After speaking with the Marketplace team they let me know that the extension developer knows about the jar conflict and they are working on resolving this but there is no ETA on when a new extension will be released. Ozgur is correct, you do not need this extension to connect with the PostgreSQL database if you are already using the PostgreSQL version of ThingWorx.
Meghan
