Hi!
What is the expected output of the Prediction Microservice when scoring against a Cluster model?
Below a capture when the PredictionThing.RealTimeScore was executed
Is it indicating to which cluster id the input data belongs to? In the case that is correct, what is the expected output when the input data does not belong to any cluster?
Nahuel
Hi Nahuel,
The expected out put is a datatable. The results should look similar to the screenshot below.
Let me know if you have any further questions.
Warm Regards,
John
Hi Nahuel,
Warm Regards,
John
Hi @nahuel
If you feel your question has been answered, please mark the previous response as the Accepted Solution for the benefit of others with the same question.
--Sharon
