Problem in Launching thingworx through tomcat due to extensions.
se1
8-Gravel
8-Gravel
Hi, I have a problem in lauching thingworx through tom cat.I guess its because when the thingworx war file is copied into the webapp,the extensions inside the thingworx folder are not generated properly.Only 4 extensions are generated.How could i solve this??
6 REPLIES 6
Hi.
Share your Tomcat Error Log.
Thanks & Regards,
Sathishkumar C
This is the error page i get.
Hi..
Please see this folder (Tomcat folder) usually... C:\Program Files\Apache Software Foundation\Tomcat 8.0\logs
Thanks & Regards,
Sathishkumar C
pselvaraj-1
9-Granite
(To:se1)
Check both the error logs tomcat and thingworxstorage.
Tomcat, you can see logs in where your tomcat folder resides
Thingworxstorage/logs, here you can see application/script/configuration/security logs which tells you clear picture.
-Prem
wq5
6-Contributor
6-Contributor
(To:pselvaraj-1)
The script log is empty.
Please look at Tomcat logs. That will give some reason behind this issue.
Thanks & Regards,
Sathishkumar C
