Problem in Weather App
mvolanti
8-Gravel
i've got a problem with the service GetYahooWeatherInformation.
When i test the service tw said me the exception: Wrapped org.apache.http.NoHttpResponseException: xml.weather.yahoo.com:80 failed to respond Cause: xml.weather.yahoo.com:80 failed to respond.
Can anyone help me??
2 REPLIES 2
ttielebein
(To:mvolanti)
Hello, what does the REST call to yahoo look like, the one which gives you this error (or rather, the part of the service which actually attempts to call Yahoo). A lot of Yahoo's weather REST API is deprecated. There is documentation demonstrating how to retrieve weather information from Wunderground located here: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS228421
Hope this helps!
Tori
As mentioned in https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS228421, i created a a mashup, when i am trying to execute, i go the following error.
17:06:34 ERROR - Error in invoking service DynamicThingTemplates_WeatherTemplate, GetYahooWeatherInformation, Things, Beta, Services, GetYahooWeatherInformation. Error from the server: "Wrapped org.apache.http.conn.HttpHostConnectException: Connect to api.wunderground.com:80 [api.wunderground.com/104.64.150.10] failed: Connection timed out: connect Cause: Connect to api.wunderground.com:80 [api.wunderground.com/104.64.150.10] failed: Connection timed out: connect".
My service script is as follows:
// Need to make a free wunderground.com account to get this key
var apiKey = "381603bc1002b5ce";
var temperature;
var humidity;
  //Inputted location needs to be valid lat, long: 40.7127, 74.0059
if(location != null){
     var test = location + " ";
    var arrayLocations = test.split(",");
    var lat = arrayLocations[0];
    var long = arrayLocations[1];
     var prm = {
        url: "http://api.wunderground.com/api/"+apiKey+"/conditions/q/"+lat+","+long+".json",timeout: 60000
     var json = Resources["ContentLoaderFunctions"].PostJSON(prm);
  try {
        temperature = parseInt(json.current_observation.temp_f);
        humidity = parseInt(json.current_observation.relative_humidity);
        me.Temperature = temperature;
        me.Humidity = humidity;
        result = "Success. Properties are updated.";
          } catch(err) {
        logger.error("Could not parse temperature and humidity for location: " + location
           + ". All valid Longitudes and Latitudes values must have decimal points"                      + " and be located where weather measurements are commonly taken (near cities).");
        result = "Failed. Check Script Logs";
But when i am trying to enter the URL via chrome browser (http://api.wunderground.com/api/381603bc1002b5ce+/conditions/q/16.57039022046052,77.50030517578125.json)
i got the results properly in JSON format.
But when i am trying to execute from mashup, the got the error.
can anyone help me to resolve the issue.
Thanks in Advance
Gnanamuthu Lucas
