Hello Community,
I have assigned the Row Format with the state definition for my datagrid on mashup. With this It shows me the entries in colors as you guys can see below.
Now the problem is that when the row is selected i want to assign it a border with black dots and i have implemented that functionality as below but still it does not appear in the mashup. it comes for a second but then the above state definition comes on top of it and i cannot see the border with black dots for the selection. do you guys have any solution in this regard. I really want to show user when he selects a row, it needs to be shows as selected. I am using thingworx 9.3
Hi @MA8731174
I have seen some type of issue with different SF cases. The issue was resolved in version 9.4 and higher. Also, if possible, open an SF case with the PTC support team. We will check it with the R&D team.
@Surya_Tiwari do you have any idea about this? If Row Format has assigned with state definition then it does not show border on selected or many other styling properties. I am using thingworx 9.3 but in the old version it works actually. Would you please see in this issue.
Hi @MA8731174
This is a know issue with some versions of ThingWorx. Please review Article - CS391589 - Grid's Selected row style is not visible at runtime when state-formatting is applied through RowFormat in Thingworx
The issue was noticed in ThingWorx 9.3.x and is addressed in ThingWorx 9.4.x
