Hi, all
I'm trying to use a schedule chart for the state of a machine.
I am trying to configure the mashup through two steps for the master mashup, but the size of the schedule chart is not fitting normally.
A mashup was composed using the mashup contained widget, it looks normal in the contained mashup view. but In the upper mash up, the schedule chart is not displayed normally.
What can i do ?
Thank you.
in Mashup contained view
Upper mashup view
Hi @SH_KIM.
Can you provide more details of your use case? We noticed in the time line, the dates jump from weekday/date to month/date and then back to weekday/date. Is there possibly an issue with the data?
As far as the issue you described, this could be a binding issue or a service execute issue.
--Sharon
Hi @SH_KIM.
--Sharon
