Is there a way to do that? I have only found the services to set REMOTE bindings
I am using Thingworx 8.5
Hi @MD_10146790 @PL_10181372 ,
pls check the following links
https://www.ptc.com/en/support/article/CS233812
Kindly revert back if you have any further queries.
Regards
Bhawna
I have already read those two
But it does not explain how to set LOCAL property bindings. It has parameters to set REMOTE property bindings only
