Can anyone please let me know how to remove this input and label from this widget. Actually i am sending everytime dynamiclly data of key value pairs from back. i dont need the input and label on it again. Please have a look in the attached picture.
Hello @MA8731174 ,
In the attached screenshot, I can see that you have taken only 1 key-value pair. I believe that this widget is not appropriate for such use-case. Instead of using Property Display widget you can try using Grid widget. Kindly check the link for more clarity:
Let me know if you have any further queries.
Bhawna
Hello @MA8731174 ,
Bhawna
Thank you for the quick reply. I got my solution. PTC at its best!
